Loosing power after driving for a while
Discussion in 'General Tech and Maintenance' started by 99sidude, Jul 24, 2006.
  1. 99sidude
    Ohio
    Setup: 93' b18c hatch
    AEM CAI
    Stock radiator
    No CEL's
    My car feels noticably weaker in the midrange (2000-5500) after I have been driving for 20 minutes plus. I have no issues before that, and am getting no fluctuations in the temperature gauge. Under normal driving (1/2 throttle) it feels less torquy, and when I wind it out, the car still feels sluggish untill normal power kicks in when I exceed 6000 RPM's.
    Any ideas what it could be?
  2. 93vicb16a2
    93vicb16a2 WHATS CRACKIN??
    bfe
    have you checked your plugs dizzy cap and wires??
  3. 99sidude
    Ohio
    The car has new plugs and wires
  4. 93vicb16a2
    bfe
    i would check the dizzy cap and roter and if you have a fuel pressure gauge i would check that too fuel pump could be getting week i had ine do that shit one time
  5. 99sidude
    Ohio
    I will check thoes things out. It just baffles me that this only happens when I have been driving it for a while.
  6. 93vicb16a2
    bfe
    well i have seel weird shit working at Autozone (not anymore thank god) but chevy ign. modules are bad about that shit with heat and i have personaly had a fuel pump go week on me and kinda same shit
  7. 99sidude
    Ohio
    Is there any way to determine if the dist. is bad?
  8. reckedracing
    reckedracing TTIWWOP VIP
    NY
    yea, the car doesn't run
    20 minutes of driving = motor getting to normal temp
    intake temps heating up, etc
    pull a compression test when cold, then drive for 30 minutes and pull another compression test...
  9. 99sidude
    Ohio
    The motor was compression tested across the board at hmotorsonline where i got it. I have only put 1500 miles on it since the swap, and have taken it pretty easy. I have the numbers back at my parent's house, but I know that it was perfect. Besides, if it was the compression that was bad, wouldn't I be loosing power up top? It feels fine up top, but is just very peaky. It feels weak in the midrange. The acceleration isn't smooth at all....
