Losing Cruise With The B18 Spec R Swap?
Discussion in 'HYBRID -> EG-EK / DC' started by flydelsolsi, Mar 3, 2003.
  1. flydelsolsi
    flydelsolsi Guest
    is it possible to keep cruise if i swap a b18 spec r in my 93 del sol? if so what would be involved? would it just bolt up, since they were cruise delete from the factory. thanks a lot.
  2. E_SolSi
    depends on the ECU but if the ECU you use supports it ... you got it :)
  3. solblu
    solblu Senior Member
    Ricer
    Has nothing to do with ecu. It shouldn't be a problem. Just look at where the cable from the driver's side fenderwell goes and make it hook up the same way to your new motor. You may have to switch out TB parts for it to work. Just look at it and you'll know.
  4. solblu
    Ricer
    Actually the cable just goes to the gas pedal, so you shouldn't have to do anything. just put the motor in and it should still work.
