I have no problems with my legs. They dont hit the motor at all. The only thing my leg hit was the stock air box and i changed that to the force winder.steve is pretty much the same size as you justin... you fit fine on it...
What are the issue's with your legs hitting the engine? And if you want to look at something smaller i would take a look at the v star custom. 650 cc shaft drive low maintenance. 2008 Yamaha V Star Custom Specifications, specs, spec
I've still got plenty of time to look around, and will be taking an M50 out (in a parking lot, boo) but I may take Mike up on the offer.
And then you can become the only schmuck brave enough to ride the ZX12 By the way, the Neon is off to it's 6th person to figure out the wiring bullshit. If you wanna take a stab at it, lemme know.
Did... you.... just......The ZX12 is MUCH smoother than the Niggerbusa
