lost motion assemblies
Discussion in 'Engine Building' started by civiclxb16, Jan 20, 2005.
  1. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    hey i was talking to one of my boys and he told me that i should look at changing my lost motion assemblies, but he had to go so he didn't explain it to me but i was wondering what exactly is that and what does it do?
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    Yes, a bad lost motion assembly will cause a valvetrain tapping, and causes the valve clearences to go out of spec much more frequently. As for the oil, the added pressure causes a pin to lock and engage the big lobe.
    Check the operation of the lost motion assembly by pushing on the mid rocker arm. The lost motion assembly should compress fully and operate smoothly through its full stroke. Replace the assembly if it does not work smoothly.
    google search... as to what exactly it does, no idea
  3. phunky.buddha
    Dallas / Fort Worth, TX
    :readfaq:
    I wrote something up about it in there.
  4. phunky.buddha
  5. formby
    formby learning in progress
    yeah Noob
    just kidding....
  6. reckedracing
    NY
    ahhhh so sweet
    i feel myself getting smarter
    lol
    nice write up too by the way
    thanks again calesta
  7. phunky.buddha
  8. civiclxb16
    Poconos pa
    http://www.hondaswap.com/forums/index.php?...50295&hl=formby
    :lol: :lol: take that :lol: :lol:
    ok i read the article but what exactly do you know when it is time to replace them? because i have a small tapping sound in my engine but i thought it was the valves tapping
  9. phunky.buddha
    You really can't tell if you need to change the lost motion assemblies without opening up the head first. Flip up the rocker arms and press on the LMA with your finger. Press it until it bottoms out. It should feel smooth and bounce back up when you release it. If they don't pop right back up or feel "sticky" then you need to replace them.
    Some people just soak their LMAs in motor oil for a day or two to loosen them up and throw them right back in, but I've never had that work for me- even after soaking them for over a month.
  10. civiclxb16
    Poconos pa
    lol dam a month, ok next weekend i am putting in my cams so i will check it then but i was wondering if my sohc vtec LMA will fit in, since honda wants an arm and a leg for one
  11. DelSlo
    DelSlo Senior Member
    hmm i geuss kinda like doin lifters? i wonder if you can clean them out and then soak em, dont know if varsol would be adequate.... personally im not the person to take the valvetrain apart and soak em and hope it all works, but when im not doin them and someone asks me whos cheap, ill say to do that! haha thanks calesta! :D
  12. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    I'm thinking :no:
  13. civiclxb16
    Poconos pa
    thinking or know for sure??? :bash: :slap: :hide:
  14. civicious
    Houston, TX
    Go ahead and use SOHC D-series LMA's. Have fun. Be sure and let me know how it turns out.
    :tardcart:
  15. civiclxb16
    Poconos pa
    ok ok just asking man :fosho3: :thankyou2: :giveup:
  16. phunky.buddha
    I actually think that they're interchangeable... at least in terms of actually fitting into your head. If they can be swapped, I still don't know what the clearance difference is between the B series and D series LMAs.
  17. D See 2
    D See 2 Senior Member
    Baltimore, MD
    I doubt that the d-series will work... especially since there are only 4 per head.
  18. phunky.buddha
    I dunno. If it fits, it just has to match the B series' LMAs for height and clearance and they'll work. It doesn't matter if there are only 4- you can always buy more.
  19. D See 2
    Baltimore, MD
    Correct, but they do not look the same to me at all.
  20. phunky.buddha
    :shrug:
    I'd have to look at them up close. I haven't seen a SOHC VTEC head taken apart before- just B and D non-VTEC. :lol:
