Lots of D-series stuff CHEAP and FAST!
Discussion in 'Parts: For Sale/Trade/Wanted' started by Dasfinc, Mar 4, 2008.
  1. Dasfinc
    Dasfinc New Member
    I stuffed a B18 into my hatch and now I have a buncha goodies forsale.
    I have a FULL D16Y8 head *SOLD*
    I have a FULL D16Y8 Intake Manifold *SOLD*
    I have a Custom Shaved Megan Racing light weight crank pulley (Custom as in I had my machine shop test the quality of it, and then shave the PS and AC part of the pulley off, so it is JUST a crank pulley for your alternator, weights nearly nothing, comes with the bolt/washer already in it) $60 shipped anywhere in the US
    I have a BARE D16Y8 throttle Body, $8 shipped
    I have a full 1992 Civic CX wiring harness with a few splices *but its all intact* as WELL as a D16Z6 wiring harness that has been cut up, but has plenty of useable wiring to convert the CX harness to Vtec $40 shipped for both
    No-Name Tri-Y D-series header WITH a nearly new BOSCH O2 sensor still in it, $60 shipped anywhere in the US.
    D15B8 *CX* Transmission with a bad main bearing $15 picked up, good for parts or to pull the 5th gear out of.
    Thanks all for viewing!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just to let you know all 92 civics came wired for vtec,,and what state are you in free bump ,..........
  3. Dasfinc
    Dasfinc New Member
    I'm well aware they all came wired for Vtec from the ECU to the shock tower,
    I am selling the ENGINE side harness which does NOT include wiring for Vtec, I apologize that I didn't clarify that.
    I'm located in Ottawa IL 61350, thanks for the bump
  4. Dasfinc
    Dasfinc New Member
    Back to the top!
  5. EGProject
    EGProject YEEEEAAHHHHH
    Whitinsville, Massachusetts
    Location? Possibly interested in the header.
  6. Dasfinc
    Dasfinc New Member
    Ottawa IL 61350.
  7. j8132727
    j8132727 New Member
    hey much did it cost you for all the parts not including labor
  8. Dasfinc
    Dasfinc New Member
    for my ENTIRE minime swap I've spent probably 800-900 because I replaced EVERYTHING in the process (Gaskets, water pump, belts, etc etc etc etc) because I thought I was keeping this setup. made a lowball offer on a B18B1, and the seller said "Sure" so I couldn't pass it up.
    You can do a budget minime swap and still replace the stuff you need to replace (timing chain, head gasket) for less than $300 EASILY and if you do it on a CX you gain a solid 40-50hp which for $300 is a bargin. (at least I could since I now know where to get everything for the best prices through this experience of mine) The stuff I had/have for sale was almost all custom or high-end though and not junkyard bits.
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    pic of bare throttle body?
