Low Temperature Thermostat/Thermoswitch
Discussion in 'General Tech and Maintenance' started by mdixonjam, Apr 10, 2005.
  1. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    They say low temp thermostats and theromswitches help to reduce engine temperature by activating the coolant/fan at lower temperatures. This should help to save the engine, minimize possible detonation and help engine performance.
    Has anyone tried it?
    Does it work?
    If so, which one to get - Spoon, Mugen, JR (Jackson Racing) ?
    Is it good for N/A applications?
    Thanks
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    Its not necesary, but if you really want your motor to stay cooler, rig a switch in lin ewith teh power to the fans. Thats the ghetto, cheap, "ricer look" way :imgone:
  3. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    They are really not helpful except if your car is a hard core track bitch. For normal daily driving, the cooler temps will make your car run richer, thus getting worse performance and gas mileage.
  4. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
    Increase your cooling capacity so that your cooling system can do a better job of keeping the engine at optimal operating temperature- but don't try to overcool the engine.
  5. mdixonjam
    mdixonjam Member
    What do you recommend to increase my cooling capacity ?
  6. pissedoffsol
    steer away from those things....
    if you want better cooling, step up to a fluidyne or pwr aluminum dual core raidator, and a fal fan
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yip, I drive my car like a mad man, autobahn for hours, around town, and once in a while on track, and my Fluidyne keeps it plenty cool.
  8. asmallsol
    if you don't have AC, you can always go with an integra radiator or any other radiator for that matter that is about that size, and just weld up your own mounting points.
