lower radiator hose
Discussion in 'General Tech and Maintenance' started by 123, Oct 29, 2002.
  1. 123
    123 Junior Member
    i need to replace my hoses, to change the lower hose do i have to remove my bumper? which is the easiest way. the car is a 91 civic sedan..
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    I wouldn't remove the bumper, there is no reason to. Remove your airbox from the throttle body foward. This shoudl give you some more room. If not remove the distributor. That should be enough room, but I am not 100% since I haven't done this in a long time.
  3. LSVtecSdn
    LSVtecSdn New Member
    tryi just removing the shroud below the bumper to gain acces from underneath
