lower rear floor bar
Adjustable to fit in any car ! Mounts in a central spot in your car between the front and rear seat floor. Bolts into your seat-belt mount.
it crap only one bolt on each side will still allow it to flex and due f all
i have the du-lock one in my car. what it dos is keep the mid part of the car from flexing to much... it is very nice would not give it for nothing...
the one from jc-whitney i could not tell you how good it is but the du-lock one is very well made and if i get a chance ill send i pic of it to show every one... :ph34r:
If you can afford anything made by do-luck, you should be able to spell it correctly.
Otherwise, you're 15 and your parents bought it for you.
:blink:
hey crvtec it is a onest mistake not like you make them to.. and on the money part tell your parents to have my check ready ill come and pick it up later... damn i did not know i was 15 i must of lost track of time :blink:
