You are going to need a lot of pressure off that turbo.... boosted GS has an LS with an 18g on it, and makes just about 200 whp at 7 psi
you have a smaller motor, and want 70 more horses out of it.
its possible, but you are going to be running 15-18 psi off it, and frankly, why no just start with a bigger turbo?
What I'm saying is DON'T do the headgasket no matter what you do. lowering your compression means you have to turn up the boost even more to make up for it. 10.4:1 is not crazy high.
personally, i think 270 whp on a stock motor for a daily driver is an oxy moron. It simply isn't safe if its your only mode of transportation.
hondata tuned or not, thats a LOT for a stock motor to handel. it may last a year, but it might blow up in a week. its a risk you have to decide for yourself if your willing to take.
