Lowering Question!
Discussion in 'Wheels / Suspension / Tires / Brakes' started by npk9, Apr 28, 2004.
  1. npk9
    npk9 Junior Member
    I was wondering if you guys can help me out. I just got a 97 civic hx (not much pontential I know). But I'm not too interested in high performance as I am just having my car look nice. I just got 17" rims on it and I would like to lower the car. I'm not sure which way to go - I've done searches and I only come across threads that are appropriate w/cars that go a lot faster then mine. I'm not sure where to start - if you guys can give me some direction that would be great!
    Thanks! :snail:
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    I would recomend some good quality spring and strut combo. as far as springs go I like eibach, nuespeeds, or teins. As far as struts, tokiko or KYB. look into those first and see what works for your wallet. If you want to adjust the height of your car from time to time, you could go with a coil over setup, but ask yourself how often would you really do this. Also changing the height of the ride changes the geometry of the car and you may have to align it after everytime you make an adjustment.
    matt
  3. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    a really common combo, is Ground Control coilovers with KYB agx / Tokico Illuminas / Koni Yellows
  4. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    or you could run skunk2 coiloverz and koni yellows :)
    they will give you adjustability and a nice firm sporty ride
    if you're just going for looks and don't give a damn about handling or peformance (which you should) you could always go with a simple set of lowering springs :shrug:
  5. npk9
    npk9 Junior Member
    So then it is safe to say that I shouldstay away from the cheap stuff like Bomz and HP. I was just wondering how all of them differ.
    Thanks for the input :worthy:
  6. Smonkeyboy
    Spokane, WA
    actually even though HP is cheap, ive never really heard anything bad about them. ever, soo those might not be a bad decision.
  7. npk9
    npk9 Junior Member
    How about dropzone? ever heard of them - are they reputable?
  8. smooth_criminal
    smooth_criminal Senior Member
    Just as a referance for you i have a 96 4dr with 17's and Eibach sportslingsprings with KYB GR-2 shocks and the rides great. About 1/2 of a finger between the tire and fender.
  9. pissedoffsol
    dropzones and stock struts.
    why dump the money on something good if you're not into performance?
