A while ago someone told me that a good way to get 11:1 compression on my 96 ls motor was to use JDM b16a pistons. But, what year will I need them out of? Anything else I should know? Let me know, thanx.
if you do CTR's you'll be around 12.5:1 CR, what gas do you plan on running on, what kind of tuning?
i suggest sticking with JDM b16 pistons, anything from 92+ (i think that is the years of the SIRII) will work.
Originally posted by SpodaB1@Mar 16 2004, 08:49 PM Actually you can use any generation of B16A (SIR) pistons. Im using SiR1 Pistons in my LS. Good luck.
