ls and gsr trans
Discussion in 'General Tech and Maintenance' started by 97hatch, Apr 5, 2004.
  1. 97hatch
    97hatch ?
    Anderson IN
    how would i tell the diffrece in a gsr and a ls trany if they are both a y80 is there any other way to tell them apart
  2. 97hatch
    97hatch ?
    Anderson IN
    ttt
  3. HellBentHONDA
    HellBentHONDA Senior Member
    wa state
    how fast can yu go in third gear before rev limtr kicks in?
  4. 97hatch
    97hatch ?
    Anderson IN
    its out of the car and i dont want to take it apart and count the teath on the gears
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    not sure about this, but try putting an axle in and turning it and see how many rotations the main shafts goes for each full rotation of the axle shaft, or the other way around actually, see how many rotations you need from the axle to get the main shaft to make one full rotation... not exact but you should be able to figure out if its a gsr or ls... no?
  6. smooth_criminal
    smooth_criminal Senior Member
    There should be a black stamp on the housing and it sould say V4D The type R says J4D and the LS i'm not sure. Let me check
