Ls/B20 Vtec (High compression -Low boost)
BSRHatch316
Straight to the point - i see the threads and the videos on ls/b20 vtec builds. Most suggest the same thing. ls/b20V all motor high compression or low compression turbo. Anyone Have an engine built with ls/b20V build running sligthly higher compression ( for a ls/b20v ) running low boost? - just looking for info/advice on this setup before i start my build.
