ls build?
doezitmater
i just got my hands on a 1994 integra, i am going to build the non v-tech motor for boost. I would like to run around 15 pounds .. i was curious to know what kind of cams to put in it. and i was thinken about using eagle rods and wiseco pistons with arp head bolts but im not sure if thats a good and strong way to go .. and i also dont know what kind of head gasket to use .. any suggestions?
Those pistons and rods will be fine for what you are wanting. Definetly stick with oem acura headgasket, I would order directly from them. The arp headstuds are definetly a good idea also. You could upgrade the head with some turbo cams and with springs and retainers from crower or someone else. But you will still make good power without them, its up to you if you want to spend the extra money. I would probably keep the factory cams and get a edelbrock intake manifold and throttle body for a little better air flow.
