ls clutch, b16a trans
Discussion in 'HYBRID -> EG-EK / DC' started by mattcalica, Oct 15, 2002.
  1. mattcalica
    mattcalica Senior Member
    k, i bought a ls clutch, because my motor was supposed to come without trans...but it came with a trans...so can i put the LS clutch on the b16a trans?
  2. pissedoffsol
  3. RoadRage
    RoadRage Member
    Well I know the 90-91 LS and 92-93 LS cable's had 2 diffrent spline's and the 94 and up I'm not sure about. So there's a chance it might not work. Not only that, Is the LS flywheel the same as the B16's flywheel. The whole clutch assembly might not even bolt up to the B16 flywheel..........
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Get the clutch that matches the tranny. The 92 Integra clutch should work with the B16 tranny.
  5. B16teg
    B16teg Junior Member
    the clutch will work all b series parts are interchangable you just have to make sure that you are using either the full ls tranny or the full b16 tranny (flywheel) or they will not line up
