ls eg ?
vadersi
I just bought a 92eg with a 00ls motor in it,, when i got it , it was running on the stock p05, cx single wire o2 ecu... I have a p75 now and wired it for a for wire o2.. when on the dyno I went to check timing and it is not in sight on the timing light, the thing is it made good power bone stock made 129WHP and120TQ.. Wheeen I started looking around the distributor is the one that came with the ls motor the plug is cut off of it adn wired into the stock main harness all wires conected have the same wire colorand all wires are hooked up, the only senser I notice that isn't hooked up is the crank position down by the crank. but I asume it is picking it up from the cams,, NO CELS either.
Thanks
why cann't I find timing with a timing light it seems it is 180 out, even check tdc adn it lines up on the crank pulley. used 2 timing lights to
