Ls Engine Wireing?
Discussion in 'HYBRID -> EG-EK / DC' started by dwn2low, May 29, 2003.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    Ok I am having a hard time figuring out where all these wires connect to on the LS engine I just put into my 92 Civic HB CX. Can someone help? What is not used where does it all go? Helms is on back order so I don't have a manual but I need as much help as possible now.
    Thanks
  2. pissedoffsol
    assuming you have the same obd engine as you do car, plug it all in, covert to a 4 wire o2, plug up the pvc if necessary (some ls's have it, some don't- im not sure what the cx has for stock) and you're done.
    you gotta be more specific on whats not working dude
  3. dwn2low
    Little Rock AR
    I'll try to take some pics and ask again.
    Thanks
    Mark
