ls engine
Discussion in 'Engine Building' started by roach009, Dec 24, 2002.
  1. roach009
    roach009 Member
    i wnat to put type r pistons in my ls integra b18b engine i need to know if it will work or should i just use gsr pistons i need to get the most power from my ls without usiing turbo
  2. pissedoffsol
    if you want to get the most out of an LS, think head work, not bottom end. while adding pistons will give you a bump in compression and a little more horse, there is much more power to be gained by running larrger cams, ported/polished head, trade the ls tranny for a b16a tranny, things like that
  3. possessed imports
    possessed imports Banned
    this guy knows his s**t you will get a good kick out of your car if you do get pistons, more aggressive cams,port/ polish the head, and 4 sure change the trans for a b16 trans that alone you will notice the difference.
    while you are at it change the intake man JG and the throttle body for a bigger one ;) :D :D
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    :readfaq: :readfaq: :readfaq: :readfaq: :readfaq: :readfaq: :readfaq: It is in the damn FAQ. ITR/GSR pistons DO NOT fit LS rods.
