LS into 88 si swap question
Discussion in 'HYBRID -> ED-EF / DA' started by 88rexsi, Oct 14, 2005.
  1. 88rexsi
    88rexsi Junior Member
    I have probably decided to swap an 90-91 ls motor into my 88 si. I was just wondering if use the engine wiring harness from the ls motor, or the engine wiring harness from the stock si motor? Should the ls motor harness connect to my car's main wiring harness? Or do I just connect all the connectors from my engine harness to the LS motor? I just want to make sure I wont run into any wiring problems.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    always use the engine harness from your car on the new engine
  3. 90sihatch
    90sihatch Senior Member
    the si harness will plug right up to the ls ecu
  4. jlicrx
    Colorado Springs
    the engine harness doesn't plug into the ECU - the engine harness plugs into the chassis harness, which in turn plugs into the ECU - that is why you use the engine harness from your car - it plugs right into your chassis harness - not all harnesses are alike as far as wire locations in the connectors and some have different connectors, depending on model and year - for instance, the 88 Si has a square 6 wire connector where it plugs into the chassis harness on the driver's side and the 89-91 Si harnesses have a round 8 wire connector, as does the LS - your harness will plug into the sensors on the LS engine
  5. 88rexsi
    So you are saying, that becuase I have an 88 si, I will need to use my engine harness then? How sure are you that my harness will fit the integra motor? 90-91. Does it have to be a 90-91 integra if I use this method of wiring?
