Ls into DX
korey
I was wondering if I could use the existing sensors from my 97 dx when I swap in my 96 ls motor? Will they work or will I have to buy all new ones. Some one help, thanx.
you need to re wire two items. Look at the following
Well, I don't know what to tell you if you don't know how to wire things in. But here's a diagram of mine that shows how to release a pin from an OBD2 ecu plug:
http://www.ff-squad.com/tech/wiring/obd2.pin_removal_1.jpg
As for wiring harness go, reusing your existing civic harness on the LS motor, will work just fine. You'll just have to perform the IACV fix and CKF fix. This is all explained in this diagram of mine:
http://www.ff-squad.com/tech/wiring/wiring.96-98.jpg
...and here's an additional diagram for the ecu pinout swap for the IACV:
http://www.ff-squad.com/tech/wiring/wiring.96-98_a-plug.jpg
info provided by Katman
