LS Motor - Full Throttle Problem
Discussion in 'HYBRID -> ED-EF / DA' started by r00twayne, Mar 25, 2007.
  1. r00twayne
    r00twayne Junior Member
    Hello everybody,
    We have this problem where if we go full throttle the motor bogs down completely, as in if its idle or gonna shut off. You go like 90% throttle the motor rips. I am thinking is a distributer problem but we haven't gotten a hold of another dizzy to try out. This is an obd0 ls motor running with a pr4 ecu.
    Anybody else having any ideas? Only codes we are throwing are 1 and 14 (o2 and iac).
  2. ls_efhatch
    ls_efhatch New Member
    i got this problem to....i dont really know what it is....at full throttle once it hits like 4500rpms it wants to stop going...but if i let out of the throttle alittle it revs to 6000...i cant figure it out...
  3. r00twayne
    turned out to be our tps wiring, two of the wires had to be switched on the connector
  4. r00twayne
    what obd u running and what dizzy?
  5. ls_efhatch
    im running an obd1 motor with obd0 ecu and dizzy....but i think i found my problem,fuel pump is giving out and sometimes wont cut on...so imma get a new one...
