OK. So I'm in a need of some help. I;ve search a bit on Google, and looked at the Swap forum, but still can't find the following.
I have been told so many different things on the Hardness. Can anyone just make it a bit more clear for me.
I was told to use my EX and only swap the Distributor plug for the B series plug, and extend the ITA ore re-wire and use the ITA from the LS motor.
I got the rest down. I need mounts for tranny, and motor. And the Integra Axles.
I'm just stuck on the wiring part.
The car is a 00/ Civic EX. D16y8 Vtec 5spd. (OBD2)
The motor is a 94 Integra LS. Tranny, ECU, Wiring hardness, ECU, and axles. (OBD1)
