Wanting to know if I can run a stock ls head on a ls block that has been tapped for vtec..... also how can i tell if the block has been tapped for it?? if it matters its a b18a1
Yes you can you just have to plug the hole where the block was tapped for VTEC, make sure you plug it good though. How can you tell if it has been tapped well look for a hole on the back of the block it's an oil feed for the VTEC.
you have to get cams with the VTEC lobes...the ones for an LS wont work..youll have to use like GS-R, CTR, or ITR cams...at least thats what i would assume.
