YES. The LS rods have the same length and main journal (crank end) size as the D16 rods. They do have to be machined down a bit because they're a tad too wide at the crank end (don't remember exactly how much), and the bushing size at the piston end is too large. You have to get a set of bushings to take the piston end of the rod down to 19mm instead of the B series' 21mm. There are exceptions though- one particular set of D series pistons has a wrist pin size of 21mm.
formby@May 10 2005, 06:37 PM no
b16. rods..
"panda motor"
jdm supra/ usdm vittara pistons will work
Originally posted by Calesta@May 11 2005, 09:10 PM They do have to be machined down a bit because they're a tad too wide at the crank end (don't remember exactly how much)
