Ls Rods
Discussion in 'Forced Induction' started by ALLMOTO, Apr 14, 2003.
  1. ALLMOTO
    ALLMOTO Junior Member
    I was thinking of turbocharging my B18B, but how much boost will the rods take? I was going to get forged pistons, block guard, girdle and intercooler. I might get a hondata eventually.
  2. allm0t0rsir
    allm0t0rsir Member
    if your going to get all that just get after market rods.... stock ls rods can handle about 10lbs boost on a stock motor
  3. tomtom
    tomtom Senior Member
    central, cali
    u must not know the man "stupid"
    this guy ran 11s with a stock ls block
    he dyno over 280hp and shot 50 direct
    all he got is a block gaurd
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    streetwise that wouldn't last long
  5. tomtom
    central, cali
    how many runs did it last?
    better yet how much torcher did it take?
  6. liquid00meth
    Laconia, NH
    Don't know, but I know 280HP on a stock bottom end probably won't last a month of moderate/hard driving
  7. pissedoffsol
    st00pid is an INSANE tuner. he's probably #1 or #2 at worst as far as tuning gods go. that ls/t car is his girlfreinds. go figure it being sick.
    also, its got hondata. Frankly, if the choice were stronger rods or fuel management, hondata would own over aftermarket rods any day for reliablilty.
  8. Baker
    Baker Senior Member
    Schaumburg, IL
    someone i know out here can build a turbo set up and tune it on stock ls internals to 245-250 hp consistently, and yes they last my friend has put about 16,000 miles on his setup and its still running fine
  9. tomtom
    central, cali
    ask ur friend how much power can a ls block with crower rods and je pistons take
    no block gaurd or sleeves...
  10. pissedoffsol
    hondata tuned, 350
    hacked, chipped, gayed out, 220
  11. tomtom
    central, cali
    i m going 4 hondata with boost and the new nitrous program.
    i take it i can t get 400hp out of the crower rods and je piston.
    Or is it the walls??
  12. RENR
    RENR Senior Member
    los angeles
    if my daily driven d16a6 can take 10psi on stock internals, and ls shoud be able to do 12-14 with good fuel management. :p
  13. st00pid
    st00pid Junior Member
    we made 293whp and 272 tq on shami's stock LS with a block guard on pump gas, The car is still running strong after a year and a half of 11 second runs,street racing, and daily driving in hellish houston traffic. The only failure has been a 10yr slave cylinder and a 3 year old stage 5 clutch masters clutch ( it was installed used from my 500whp street hatch.)
    The longevity of the motor can be attributed to a conservative tune and the fact that we take pretty good care of the maintenance of the car.
    jason
  14. pissedoffsol
    its the walls.
  15. tomtom
    central, cali
    About time bro.
    everyone was doubting the ls block.
    I guess i better tear the head off and install a block gaurd.
  16. ALLMOTO
    hehe. I might make some people mad, but I might go with a LS/VTEC instead (NA). Will the stock rods handle 8k pretty good? So long as I get all of the internals balanced? I was thinking of using the stock crank and ITR pistons.
  17. liquid00meth
    Laconia, NH
    Ls bottoms are not meant to be revved high. You can probably get 8k though, don't be looking for no 9-10k thought.
    8k might blow it, im not really sure
  18. tomtom
    central, cali
    u wont come close to 250 hp they will do fine.
    Just take ur block to a manchine shop and get it balance
    (If u get the rods shot pinn balance and the crankshaft micro polish it ill run around $400)
  19. pissedoffsol
    z10 block girdle helps too
  20. 97ExC1T3_To4e
    97ExC1T3_To4e Junior Member
    I've been running a 97 EX with a GSR swap and the following for 12 months now of daily driving and weekly track runs.
    Low compression head gasket
    cam gears
    440cc injectors
    apex SAFC
    Clutch masters HDCB
    Quaife Diff
    Turbo kit including: t3/t40E 60 trim turbo, InlinePRO stainless steel exhaust manifold, Turbosmart 38mm wastegate, Front mount intercooler, Greddy Type S bov, FMU, 255lph intank fuel pump, slim line fan
    Turbo smart duel stage boost controler, 12 psi street, 20 psi strip
    apexi exhaust
    And one hell of a tuning job.
    All with stock internals
    The shop that did the work has multiple cars over the last 8 years still being driven with the same setups
    Its all in the tuning
