LS swap.. and a bunch of other crapp
Status
Not open for further replies.
pelicangsr
im located in jackson heights queens around junction blvd close to 7 train
**pick up onlyy**
i have an b18a1 engine with 100k typeR pulley timing belt and water pump just got done.. no clutch, no flywheel, no fuel rail
asking for $275
i have a s1 tranny smoth no grinds no starter
asking for $175
i need cash asap.. located in jackson heights queens.. pick up only
****EVERYTHING IS BEST OFFER****
i have b-series mounts for EF's and the shift linkage..
also have a complete b20 head
mugen sohc grey valve cover
obd2 distributor
b16 crankshaft
about 50k on it..
hit me up everything gatta go
AIM: EVLBLUEYS
everything is slightly neg. depending of how fast u come get it.. pics on request.. but yah should know how all these things look like
the engine was in the whip i just took the engine out.. i had it on b20 for people to come cehck it out so they can see it runs no smoke no over heating.. i let guys test drive the car so they can check out the transmission.. guys came drove it.. and they werfe jsut a waste of my gas because noone has money..
the engine runs 100%..
the only reason im taking it out its because i built a bigger enegine an it just finished and i need cash so i can buy lil things to finish it..
only thing is.. i needed the alternator(obd0 for my crx) and the fuel rails/injectors.. intake manifold an throttle body is still on an exhaust and downpipe..
i just had the timing belt/ water pump one less then 1000miles ago... i did sell the type r pulley to by boy but i have a stock pulley to give u..
this is the title to the car jhm4db1672ms007658
it was a 1991 4door automatic integra..
Status
