LS swap ECU question
Discussion in 'HYBRID -> EG-EK / DC' started by anzi, Mar 26, 2011.
  1. anzi
    anzi New Member
    Hey guys I'm new to the fourm and same to the tuning world. I bought a LS (96 non-vtec) swapped 95 Civic a while back and I assumed the ECU had been swapped, my ASSumption was incorrect, I looked and it's the P06 so I was wondering if it would be a bad idea to buy a used P75 ECU on ebay ($45). Don't have plans to boost, maybe a chip in the distant future but debts come first. Hoping proper ECU will fix idle problems and maybe fix some other odd power issues I'm having.
    Also I've gathered that the 96-01 p75 is OBD2, I'm pretty sure the wiring harness is all swapped because there's 2 of every plug throughout the engine bay -.- Will I need any kind of conversion or a different dizzy? (not sure what dizzy is on currently)
    Thanks
  2. Briansol
    obd1 p75 ecu is what you want from a 94-95 teg ls/gs/rs/se. it's doubtful that the guy converted the car to obd2.
  3. anzi
    anzi New Member
    Aight thanks bud, any experience with or opinions on buying an ecu off ebay? They are very scarce in my area so thats looking like the most cost-efficent way to go.
  4. Briansol
    its really hit or miss. try to stay with the sellers with 100% rep (as close to as possible) and a ton of feedback.
  5. anzi
    anzi New Member
    Yea, I actually just found one locally but it's from an auto and I've seen some small traces online of people soldering to swap the p75 from auto to manual but noting in detail. If there is a good write up that is evading my search I would very much like a link.
