ls swap in eg hatch problem
Discussion in 'HYBRID -> EG-EK / DC' started by H2B_hatch, Sep 30, 2008.
  1. H2B_hatch
    H2B_hatch New Member
    ohio
    i had a major wiring issue before got it straightened out ran good. change the oil and put a short ram intake on now it hits "rev limiter" at 3k rpm.. can anyone help me? this cars driving me crazy never had such a problem.
  2. H2B_hatch
    ohio
    any ideas guys??? i had this problem in a crx once but it was cause a pin was pulling out of the ecu so i pushed it back in everytime it did it.. but this isnt that way. :confused:
  3. unuzual kustum
    unuzual kustum New Member
    Martinsburg,WV
    Recheck the oil. Fill if neccessary. No CELs? Disconnect the battery for a couple of mins. Check and see if you bumped anything during the removal of the oil filter or intake install. Maybe your ECU is in limp mode due to a loose connection to the oil pressure sensor.
  4. Matts96HB
    Matts96HB . Moderator VIP
    If you say you have loose pins in the ECU, I'd run through and check all your wiring again. Did you solder any connections?
    Also, if you don't have any CEL, that seems kinda suspicious. It should be throwing something if its doing that. What ECU is in this car?
  5. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Code 4 cranksahft position sensor....check your Ecu codes
