Ls Swap In To A Crx
Discussion in 'HYBRID -> EG-EK / DC' started by crxguy05si, Jan 24, 2003.
  1. crxguy05si
    crxguy05si Junior Member
    I have a Ls engine sitting in my garage and I am planing on swaping it in. What I was wondering was will I have to get a ZC or SiR hood seeing that im swaping in a b-series engine? I plan on using either hasport or place racing mounts.
  2. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    whats up , you can use your crx hood but yes it will hit. you need to bang in some of the supports whereever it hits. mine just eventually fit to the engine. but yes there are clearance problems
  3. jamiedude
    jamiedude Senior Member
    chesapeake,va
    i know that with my zc engine you just have to take the timing belt cover
    but im not sure about your ls buddy sorry
  4. ef6-ef8
    ef6-ef8 Junior Member
    yeah clearance is a problem. cut out what ever hits!
  5. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    WTF? Yea, lets go bang up on the braces, resulting in the hood on the outside to be pushed up. Pull the hood and cut the braces over the head out and then dont let anyone sit on the hood in that spot.
  6. slammedb18acivic
    pa
  7. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    you are using a new mount kit right?
  8. crxguy05si
  9. b18vtecrx
    b18vtecrx Senior Member
    can you get around the clearance problem by maybe mounting the motor mounts lower and over all mounting the motor lower?????
  10. D See 2
    D See 2 Senior Member
    Baltimore, MD
    i'm pretty sure that if you put a few washers under each mount, that it will clear. trial and error is the best way.
  11. cbrnascar0329
    cbrnascar0329 Banned
    adding washers is adding more metal. wouldn't that raise the motor...it also won't allow the mount to sit properly which would allow for more vibration which is already going to be more than the stock motor....i dunno, maybe i'm wrong....
  12. puffy00
    puffy00 Junior Member
    if u put hasport mounts the crank pulley will hit the radius rod when u drive and u will need bent one out of a accord so u should use stock mounts and just buy a zc hood which comes higher it happen when i did it in my crx
  13. Domeskilla
    Fort Wayne, IN
    There is not any OEM mounts you can use in the 4th gens to get a b-series in to a crx. Maybe some JDM mounts, but i wouldn't bet on it.
    I dont know if you are going find a ZC hood to easily, just get a cut off wheel and cut acouple of braces out from under the hood and dont let anyone sit there.
  14. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Damn,it isn't that hard of a concept to grasp.Like Codee said,lower you hood find out exactly where it hits,get a grinding wheel and remove as little as possible.But it doesn't matter anyway because the HAsport mount kits will clear the US hoodline.That is what they are made for,along with mounting the motors in cars that they didn't come in,in this country.
    And to crxguy05si,we are not mindreaders it would help to know what year,your putting this in.But once again,YOU DON"T NEED HOOD MODs WITH THE HAsport KIT.
    Here is the nescessary step's for your engine bay have fun a good luck.
  15. ChaseRsX
    ChaseRsX Junior Member
    I put a b18a in my crx using hcp mounts and there is no clearance problems.
