ls swap into eg axle problems
widebodyeg
need help!!!! i just did an ls swap into my eg and im having axle problems.Im using 1993 integra axles and halfshaft on a hydro tranny and when i put the driver side in, the trans wont shift and the axle breaks.I know the trans is good it shifts great when the axles arent in,its like something is binding.what is going wrong,am i only suppost to use 94 and up axles and halfshaft,what should i do?
in 93 the tegs still had the cable tranny they switched over in 94 so maybe the axles are different as far as splines
