ls swap into eg hatch
No wiring needed! Unless its OBD2A and he can still use a OBD2A USDM Engine Harness and it will plug into his OBD1 Shock Tower Harnesses. This swap is about as stright forward as it gets in Honda Chassis's.
Depends on what obd his motor will be. I used a obd2a motor in a obd2a EK used a Lx engine harness and there was still a few things to wire. Switch EVAP purge plug, changing crank sensor plug and changing some of the ecu pins. Having a EG with the 2 part harness sure make thing a bit simpler.
Yes....your are talking about an EK and I forgot that EK's are on this section of the forum too. I was thinking it was only a 92-95. But.....a USDM harness...I really thought the plugs were all the same.....but I could be wrong. Sadly, the OP did not give enough information. and we don't even know if he's checking back in.
