ls swap
Discussion in 'HYBRID -> EG-EK / DC' started by stevennn09, Jun 30, 2008.
  1. stevennn09
    stevennn09 Member
    Ohio
    is it too hard to swap an ls motor from a 91-93 teggy into an eg civic?
  2. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    nope read up on it buy the right parts and it can be done in a weekend
  3. stevennn09
    stevennn09 Member
    Ohio
    what does the right parts consist of? anything besides the usual swap shit
  4. Bkkfarang
    92-95 EG & Del Sol with a 94-2000 Integra LS B18B Engine.
    Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used.
    Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year.
    ECU: p75 from a 94-95 Integra
    Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit.
    Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
    Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
    Upper Radiator Hose: 94-Up Integra LS
    Lower Radiator Hose: 94 Del Sol Vtec
    Throttle Cable: 94 Integra LS
    Clutch Hydraulics: Stock
    Air Conditioning: 94-95 Del Sol Vtec A/C bracket
    Special instructions: Using OBD II Ecu requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on alot of potential problems
  5. stevennn09
    stevennn09 Member
    Ohio
    thanks though.
  6. BrutalB83
    Rochester Hills, MI
    If the motor comes from a 92 or 93 Integra, then the swap will be exactly the same as the one outlined above. If it comes from a 90 or 91 Integra, then an OBD conversion will need to take place...
  7. andrew256
    andrew256 New Member
    Athens, GA
    what's the best place to find a good LS? I too am thinking about going this route and turning it into a frankinstien later.
  8. BrutalB83
    Rochester Hills, MI
    Start your own thread dude...
  9. stevennn09
    stevennn09 Member
    Ohio
    thanks, does the 92-93 have hydro or cable? i think it's cable. would a b16 or gsr tranny be good to put on a ls?
  10. BrutalB83
    Rochester Hills, MI
    90-93 Integras use a cable setup. A GS-R or B16 transmission will bolt right up and help with acceleration but you might also see a slight decrease in gas mileage...
  11. stevennn09
    stevennn09 Member
    Ohio
    not to sound like a tool, but gas money really isnt that big of a deal. i make decent money for being 17. but a b16a2 si tranny would work correct?
  12. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Yes, that is correct.
  13. stevennn09
    stevennn09 Member
    Ohio
    another thing. the b16a pistons will work in this motor right? and which are ones are compatable. the ones from the ek si motor, or from the jdm sir b16a? sorry for all the ?'s i would search but for some reason it never works properly.
  14. BrutalB83
    Rochester Hills, MI
    You want the JDM pistons, and I didn't mean to sound like a dick with the comment about the mileage, I was just letting you know. If you're fine with it then yeah, go for it...
  15. stevennn09
    stevennn09 Member
    Ohio
    yeah that's what i've read. and it's cool. i'm going to put those pistons and a crower valve train, and cam gears. i'm not gunna need to tune it off the bat am i?
  16. BrutalB83
    Rochester Hills, MI
    I'd probably take it somewhere and get a tune if you're going to be swapping out the pistons and messing with the cam timing...
  17. stevennn09
    stevennn09 Member
    Ohio
    would it be possible 2 do myself? i kinda wanna learn how to tune shit.
  18. h2b4door
    h2b4door New Member
    Deff go with the b16 trans. I had an LS in my 4 door civic with a y21 trans I had a blast with it driving around town. Gas mileage wasnt bad either i was still getting 300+ in a tank. As for tuning you should look up phearable.net you can buy an already chipped ecu from them with a basemap and then just go from there :thumbsup: I have heard alot of good things about em.
  19. stevennn09
    stevennn09 Member
    Ohio
  20. Bkkfarang
    sounds like a decent plan , sorry to be short the other day with the long swap post , but an ls swap is one of the easiest swaps . are you changing cams or just pistons and valve train ?
    some after market valve train parts are great with a cam swap , but on stock cams it can be a waste of money . remember you can't rev the shit outa an Ls or an Lsvtec , any way good luck with the swap , just keep your expectaions real and in your budget
