Ls/turbo Or Ls/vtec
Discussion in 'Engine Building' started by 92hatchb, Jan 9, 2003.
  1. 92hatchb
    92hatchb Junior Member
    I have decided to do one of these swaps for my next civic, I want to know which one would be better. Its going to be a daily driver and i would like to be running mid to high 13's I am leaning more towards the ls/turbo. Any help would be awesome thanks for all of your help. For the turbo setup i would like to know what the ideal compression ratio would be because I have know idea thanks again
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    uhhh ls/turbo....
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Why are you even considering an LSVTEC? Do you already own an LS engine? If not then don't bother with an LSVTEC, run a B18C1 instead.
  4. Hexen
    Hexen Senior Member
    Davis, CA.
    If you're set on LS then definatly LS/T.
    The only real reason to go LS/Vtec is that you already have an LS and want to stay NA.
    Otherwise the GSR is the cheaper B series Vtec engine of choice.
  5. 92hatchb
    thanks for your help
