lol not really. I dont wanna take a risk when the stock sleeves can handle an average of 250-300hp and im gonna be pushing about 300 which is taking a risk.
How much power and torque should I expect out of this setup????
B18a1 block stock sleeves
OBD-1 head with dual springs and ti retainers 8500RPMS
JE pistons with Eagle rods and JE pro ring set 9:1 CR 81mm
ACL Bearings
44mm tial wastegate
t3/t43 turbo manifold
Golden Eagle Cam Gears
370 RC injectors
57trim turbo
7psi
Im still depending on if its worth getting the 62404 crower stage 3 cams 8200+RPMS or stage 2 or just leave them stock??
What kind of cam timing is best for turbo????
wow you want a horsepower goal. fine 200-300hp there you go. but i think ill just get some 440cc injectors cause I hear you can tune the injectors down if im only making 250hp or so.
[flame] After reading the majority of this thread, I'm about ready to throw up. Here blanco is trying to help you out, and you sit here and make smartass short comments.
You want to know why he wants a HP goal? Because there is NO SET NUMBER FOR POWER GAINED. Example, 4 psi does not always mean 40 hp.
Thats why he asked for a HP goal. Don't go snapping at people when they are trying to help you out, regaurdless if you have had a bad day or not.
Do your own god damn research, and stop being a dick to people on the forums. [/flame]
