Ls Turbo Vs B20 Turbo
Discussion in 'Engine Building' started by vietec, Feb 5, 2003.
  1. vietec
    vietec Member
    I AM SORRY IF THIS WAS ALREADY DISCUSSED, BUT I REALLY WANT TO KNOW WHICH IS BETTER AND MORE RELIABLE AND CHEAPER. THANKS !
  2. pissedoffsol
    reliable? either will only be as good as you build and tune it
    cheaper? the ls is cheaper
    better? see above.
    and please, loose the caps.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Equally built, the reliability is the same. The LS will be cheaper just because it's a cheaper block. The B20 will make more power because its displacement is larger than the LS.
