LS vs RS?
Discussion in 'HYBRID -> ED-EF / DA' started by EFDX, Sep 12, 2009.
  1. EFDX
    EFDX New Member
    why use the b18a1 from ls teg and not the rs? ive searched hi and low and cannot find this answer, is it the wiring? is it the availablity of the ls vs the rs? any help apreciated
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i thought the rs was only in the 94+ integra b18b1, and the ls and the rs are the same motor
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    No they have DA RS models. and you're right, the RS, LS, and GS all share the same motor.
    OP- I think you're just getting confused because everyone refers to the b18a/b motors as LS motors. It's just something that came about for some reason.
  4. EFDX
    EFDX New Member
    ok then, my next question. is the dpfi to mpfi conversion the same for a b18a1?
  5. B16RacerN2NR
    Moving back West...
    :yes:
  6. D16SiHatch
    D16SiHatch New Member
    the conversion is going to be the same regardless of what mpfi engine you swap in
  7. EFDX
    EFDX New Member
    thanks for the clarification. i have a whole donor car so all i need is the mounts and shift linkage then
