ls/vtec 210whp??
ivanB16
Since my b16 block died,im thinking on using a b18b bottom end i will upgrad mycam from CTR to Skunk stage 2 cams and use forge con rods and pistons(11.0:1) , could that set up can make 210whp or nearly??? im gonna use a Haltech ek6 for managment duties or an Hondata ,not sure yet.
I forgot to say, ita NA,without turbo,charger or NOS.
I made 195 whp with CTR cams and a b18 bottom end with CTR pistons. I think i can be done, it wont be easy however. I would get bigger cams if you want that kind of power.
Or you will have to spend big money on head work.
i made 185 whp on 12.3:1 cr 81.25 pr3 pistons / .020 mill with ctr cams
I'm calculating 12.39 compression with that setup there... so really 12.4:1.
:D
What was the torque number with that Pills?
