LS/Vtec buildup question
Discussion in 'Engine Building' started by rsaeini, Mar 13, 2004.
  1. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    Hello all,
    I'm in the middle of my LS/Vtec buildup and I had a few questions.
    -which flywheel/cluth do I use? LS? GSR? B16?
    -should I go with a lightened flywheel?
    -which crank pulley do I use? LS? GSR? B16?
    Thanks
    Ray.
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    I would upgrade to an aftermarket flywheel and clutch, now is the time to do it.
    fidanza, or most any flywheel is fine.
    clutch, well depends on your plans, if staying NA consider Clutchnet/Exedy.
  3. pissedoffsol
    i agree- upgrade :)
    at least, run an ITR setup.
    my vote for clutches goes to ACT.
    run the stock ls crank pulley
  4. DA69
    DA69 Senior Member
    psl Fl.
    crank pulley i would go with a stock one and not a lightened one there. but for flywhel i have a ITR and seems to be real nice. i lost 7 pounds and its not way too light. you dont want to sacrafice too much torque. my opinion is the ITR stuff is the way to go for that :spin:
  5. formby
    formby learning in progress
    i am in the middle of my lsvtec swap too and i bought gsr pistons and rods are the gsr rods better? will they fit right. please help :worthy: i am putting ctr pistons
  6. JDMilan
    Boca Raton, FL
    if your going no PS then I might consider shaving off the extra weight from the crank pulley, but make sure to get it balanced.
  7. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    We have been over this before on this board. You will not lose torque with a lighter flywheel. Before you bring up F = MA remember that M will be decreasing but A will be increasing.
    If you have the money go with the fidanza flywheel.
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    if you are using the LS crank in your lsvtec the gsr rods will be too long.
    also, if you have a question please start your own topic.
