LS/Vtec But Vtec wont work
Discussion in 'Engine Building' started by 92CivicLS, Jan 7, 2008.
  1. 92CivicLS
    92CivicLS Junior Member
    hello everyone.
    i have a civic with a b18a and i had a problem with the head, and i tried fixing it, but no good. it kept ticking but it turn out to be the block ALSO had a ticking noise.
    yes it was a bearing. i fixed it, and i had a GSR head with TYPE R internals that i was perfectly using and working.
    and now with this LS block, when i took it for a spin with the spun bearing, VTEc worked three time, after the thisrd time, no more.
    i fixed the block, and still no vtec, i changed the oil.
    still no vtec.
    the OIL LINE was checked. no VTEC, i check the oil pressure, (perfect) No vtec,
    i changed the selenoid 3 times, 3 diffrent ones, working in other cars too, no vtec,
    the ECu is sending signal perfect, no vtec.
    i put the selenoid direct to it clicks but when u drive NO VTEC!!
    i check the rocker arms, to see if the center pin moves, and it moves perfect. NO VTEC
    a friend of mine told me to put Marvel mystory oil, and see what happens.
    and i did. couple of hours later,
    IT WORKED!! this was at 3:00pm
    at 6:30pm it stoped.
    no more vtec.
    i've tried everything i can think of, i even called people that know their HONDA STUFF and they dont know why.
    maybe someone here does i dont know, but if you do please help me out, im about to throw that S*** away.
    ANY ideas would help please anyone.
    i've put Ls/Vtec together before and i've never had that problem before and i've used -4 lines and no problems.
    Sorry so long of a story but i had to explain.
    brake ur heads people cuz i've broken mines. its crazy.
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    WOW! Hooked on Phonics is your friend
