Ls-Vtec Gasket Q
Discussion in 'HYBRID -> EG-EK / DC' started by TWOLOUDnPROUD, Dec 1, 2008.
  1. TWOLOUDnPROUD
    TWOLOUDnPROUD LX-R coming soon
    Ok i am doing Ls-Vtec build with a B18a and a B18c1 Vtec head now what gasket kit do i use? B18c1 or do i need to piece a kit together:confused: i Know someone has the answer. By the way i did search:cool:
  2. 4drteg54321
    4drteg54321 New Member
    Your gonna need the LS Head gasket, And whatever gasket your head is
  3. jr_jdm
    jr_jdm jdm is the best
    Houston
    u need a ls gasket...
  4. RedRice
    RedRice Junior Member
    Also, I used the Inlinefour Dowel pins, I have to slightly enlarge the holes for them, I just break out the 3/4" Uni-Bit and step the hole up one size and they fit nice and snug. ;)
  5. monotech
    monotech Member
    Dowel pin kits come sized already but if you had to drill a larger hole you don't want to have any play.
    :thumbsup:
  6. shorelovr202
    shorelovr202 Integra Guy
    Latrobe, PA
    Use the LS, if you use a gsr gasket, you are prone to oil leaks.
