LS/VTEC harness wich one?
CRseX84
ok im gona do a LS/VTEC swap, with a GSR head, shuld i get a GSR harness ?? waht kinda ECU shuld i get also? im throwing it in my 91' CRX DX, if i do use the GSR harness do i have to do any modifications to it?? or any other harnes i would use?? and shuld i chip my ECU?? if so what shuld i chip it?? thanks for your help
You're in for a wiring nightmare. First you have to convert the DX to MPFI, then you have to mod a harness to fit the GSR and then plug into the CRX, along with using a chipped ECU. damn.
What if i just went streight GSR engine would i just use the GSR harness and ECU and that be it?? please say yes......
