Ls/vtec Help
9civ9
ive been building a lsvtec and need to know the tourge specs and bolting down the head i know its a three stage process but dont remeber how many pounds it should be
this probably wont help, but earlier on today i read something bout buying a helms manual to figure it out properly... hope i helped some
in the faq i have the specs for a b16 head. i dont know if it is identical for an LSVTEC, but i also would like to know that.
SHOULD BE THE SAME...since you are supposed to use vtec head studs
You have to use the VTEC head studs as the LS ones are not long enough. Use the specs that go with the studs you use. You'd be much better off with ARP studs.
3 if you want to count going back over them all again (good practice as ive found every time the first ones ive Tq'd are a little loose once the others have been brought in)
