Im pretty sure the block has the golden eagle dowel pins which dont have to be relocated. The block was built, I bought the block for 800 $ with the head and block LS vtec work already done, im almost 100 % sure the dowel kit was golden eagle, shotpeened rods, micropolished crank, forged aluminum type ITR pistons.... before it was borred over he was running the stock ls hg, the only difference between then and now is that it had b16 pistons in it and it wasnt borred over. The lsvtec hardware is all the same.
