ls/vtec how much power is it anyway??
Discussion in 'Engine Building' started by vetch22, Aug 13, 2003.
  1. vetch22
    vetch22 Junior Member
    i hear a lot about the ls/vtec i was just wondering with a good one built around how much power will the beast unleashed compared to the old time monster h22, b18c1, b18c5, thank guys this forum is the shit!!!
  2. Hexen
    Hexen Senior Member
    Davis, CA.
    That all depends on how much money you're willing to dump into it.
    The LS/Vtec is a strong setup for less money than a GSR (for the swap that is).
    If you're willing to dump thousands in.. hell you could make 500 hp.
  3. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    i heard of the ls/vtec making more than 300 whp at more than 10k fully naturally aspired.
    it really all depends how much power you want to make and how much money you have to spend.
    the mods i can remember for the motor above were
    b18b block
    sleeved and posted to 84mm
    stock crank
    76mm throttle body
    550cc RC injectors
    Hondata ECU
    Endyn 12:1 rollerwave forged pistons
    head milled
    ported and polished
    block milled
    Stock GSR crank Girdle
    modified ITR water and oil pumps
    i don't remeber the cams tho
    Eagle rods
    skunk 2 intake manifold(custom port and polish)
    thats about all i can remeber i know there was a ton of custom work tho.
    oh and it was running on 93 octane,
    so i guess it all dpends on your budget, the build above would be very expensive.
  4. JDMEK4
    JDMEK4 Junior Member
    I heard Ls/Vtec aint that Reliable
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Sounds like bullshit to me.
    Why would you resleeve and then post? Most resleeve jobs include a strutted sleeve... so posting is pointless.
    Why mill the head and block when you're already using custom pistons designed for the compression you want? That's just dumb. Resurface your head/block, then buy the pistons with the compression you need.
    Nobody's made 300whp streetable all-motor with a B series engine, unless you're talking about Larry Widmer's article that still doesn't have dyno proof yet.
  6. phunky.buddha
    You're hearing internet rumor crap from people who don't know what they're talking about, and from people who don't know how to put engines together. Go read up some more. The unreliable LS/VTECs out there were built badly or were built with worn out parts...
  7. vetch22
    Hey celesta with a good built ls/vtec motor you with all the good stuff, skunk2 manifold, rod, pistons, everything good and high performance stuff how much power will you get out of one of them thanks
  8. gyallis
    gyallis Senior Member
    Bronx NY
    Why not just answer his question, rather than blab?
  9. 2 litre EG
    2 litre EG Senior Member
    so cali
    cause there is no real answer... we cant guess HP numbers, personally 196.7hp... based off of what i know i have in my LS/VTEC this is what im making to the ground, and personaly best is now 13.23@112
    but thats me... chances that you come with numbers exactly the same as mine are SLIMMMMMM TO NONE!!!!!!
    so dont depend only on my information
  10. phunky.buddha
    There's no real way to say...
  11. gocivicls
    gocivicls Senior Member
    forest city, NC
    B)
    I read in "HONDA/ACRUA Engine performance " by HP Books,
    Typical LS with B16 or B18c head swap adds about 40 hp avg. due to larger displacement and longer stroke.
    HP-170-190 At the flywheel
    Torque-120-145
    CR-10:1
