Hey guys I have a question on placement of the knock sensor for a 92 integra ls/vtec. I am planing on using a p72 odb1 ECU. Do I need the knock sensor or will it run without one also where would be a place to put it on the block.
no idea on placement, but when I first put my b18c1 in, the knock sensor wasn't wired and ran fine. knock sensor sends no signal unless it senses a knock...run high octane you should be fine
