Ls/vtec Or B16a
i have a j speec b16a in my 91 integ. i also have a ls block in the garagewhich one will be better for turbo?
another question.
will gsr cams run better and faster in my b16a with out the turbo setup?
if you build the LS/vtec up properly, go for it. it takes more than just a block. if you don't have the time, stay with the b16.
gsr cams have slightyly more duration and lift than b16 cams.
