ls vtec or b18c1
Discussion in 'Engine Building' started by SacTownsGreatest39, Apr 20, 2005.
  1. SacTownsGreatest39
    SacTownsGreatest39 Junior Member
    im thinking about takeing apart my b18c1 enging and maken a ls/vtec since i herd that the ls/vtec is better because it has more torque and good top end. so what do you guys think? i need sum advice
  2. bunson2001
    bunson2001 Member
    thats crazy man, if it works just mod the b18c1
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    LSvtec is good when...you can fully build the block and don't have a working GSR, have a great deal on a LS block and don't have a working GSR, or have an LS and want more power without buying a whole GSR.
    If you have a running GSR you'd be a fool to swap the block.
  4. formby
    formby learning in progress
    usually people build an lsv because the cant afford a gsr and the have some parts already.....i would keep the gsr and buy an ls crank and rods just knife edge the crank enough to clear the oil squirters...and you have the nicest lsv you can build....its an ls in a gsr block...
  5. xj0hnx
    C.C.TX.
    Actually, disregaurd everything I said, and swap blocks, then sell me your GSR block :)
  6. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    +1
  7. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    WERD. The B18C1 is a great motor yo.
