LS/Vtec or GS-R Swap into a 91 LS
Discussion in 'HYBRID -> ED-EF / DA' started by Gimpo, Apr 16, 2004.
  1. Gimpo
    Gimpo Junior Member
    just wondering if anyone has done this swap or a ls/vtec before, i have everything i need to do either, turbo might be down the road but i was plaining on going internal first, i want to build a mean sleeper. any reply would be good
    thanks
  2. NotUrAverage_Si
    NotUrAverage_Si Senior Member
    ls/vtec will put down more hp and higher torque #'s than a gsr, stock for stock. although if the person building it doesn't do it right, the b18c1 will be more reliable. you doing the build yourself?
  3. Gimpo
    Gimpo Junior Member
    tapping the block and all that will be done by a shop but the wiring and the physical swap will be done by me yes and a few friends
