ls vtec p30 ecu code 36
Discussion in 'Integra' started by brandanintegra, Dec 6, 2008.
  1. brandanintegra
    brandanintegra New Member
    finaly it runs , ok i have an 91 integra obdo ,evey thing is now obd1
    a 1998 b16a head an a 91 b18a block ,5speed cable trans
    My questions is in the ecu
    ok with a stock non chiped p28 sohc vtec ecu the car runs fine,vtec works
    but now i bought a p30 jdm an the car runs like shit
    the car is thiroing a code of a 36 ,an a 23, the 23 is the knock sincer an the 36 trackion controle how can i fix the trackion controle ,
    an is ther any way around the knocksincer cause my block is not made for one
    also the reason why i bought the p30 is cause im geting my p28 chipted
  2. teggyguy
    teggyguy high density foot.
    You need to chip that ecu so you can disable that stuff. Thats the only way i know. i put a p72 in my 93 gsr (loosing compression) and it's knock sensoring it up lol. so yea my p28 is chipped to ignore knock and such.... iono otherwise. Have you purged the codes to see if they come back?
