ls-vtec project in progress
Discussion in 'Engine Building' started by brasilianstreet, Mar 23, 2004.
  1. brasilianstreet
    brasilianstreet Senior Member
    what else do i need heres what i got so far , b16 head b18a block b16 hydro tranny, crower rods and arias low comp pistons , got all si head parts like intake mani etc. stock si , also got gsr distributer ,gsr belt , gsr water pump , getting gsr axles if not those wat should i get for new axles and im getting Si engine mounts also skunk2 cams , and i got a dc sports 4-1 header, what else do i need like an oil pan or i no i need new gaskets for some stuff but i dont know what ? oh and this is goin in my 96 ex civic
  2. brc80
    brc80 Senior Member
    Southern California
    Are you planning on boosting? If so sell the header, if your going N/a Sell those pistons.
  3. brasilianstreet
    yea im planing on boosting i need to get the jdm 4-2-1 header by dc sports i mean i want to but any 4-2-1 header is what i need not 4-1 right?
  4. ef_hatch
    ef_hatch Member
    to go turbo you NEED to get a turbo header lmao
    do a search or try some of the ads at the top of these pages
  5. brc80
    brc80 Senior Member
    Southern California
    I think you need to do some more research before you tackle boosting an ls/vtec. Just my .02
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    not sure the specs on your cams that you have but they might have a tad too much for FI applications.
    also don't forget about the shiftlinkeage.
  7. brasilianstreet
    oh yea my bad i forgot turbo header but what ever i did alot of research and i got alot of friends who are helping me do my stuff . thankz though what shift linkage should i get ? and what cams also would you recomend
  8. Goldberg
    Goldberg Member
    I think skunk 2 makes turbo cams, also heard that running gsr cams would work well also for a FI engine.
  9. kyleirwin
    kyleirwin Retired OG
    Vegas
    for shift linkage i'd imagine you'd need the linkage from a '99-'00 si, but something else may work. and get some gsr cams.
  10. brasilianstreet
    alrite than thankz imma try to find some gsr cams on ebay and what abotu my cam gears? and ima see about the shift linkage?
  11. uptowng2ic
    uptowng2ic Member
    NY
    Get a hydro LS Tranny for the longer gear ratios
  12. brc80
    brc80 Senior Member
    Southern California
    Wrong, if you can get a gsr tranny.
  13. AcUrA_TuNeR
    AcUrA_TuNeR Junior Member
    Forget about the GSR tranny... LS tranny is better for Turbo appz... Why? Well the answer is simple... The longer gear ration of the LS tranny allows you to stay longer in the peak HP so you get torque for a longer period... GSR tranny shorter gear ratio will make the car start faster because it reaches the peak HP faster but... 1/2 a sec later, LS tranny will overtake you...
  14. brasilianstreet
    i understand what you trying to say but shit i already got the tranny . but the Si tranny i got will still do good with turbo right?
